Greg Rozar AKA- CubDieselFan
Old 02-12-2019, 03:12 PM
BigAltoona BigAltoona is offline
Default Early model 1862 with 451 snow blower
Hello my fellow Cadet owners, new member here. As the title States I have an early model 1862 that came with a blower that I purchased last spring. Come snow season (WI) I attempted to blow the snow but to no avail, I wrote it off as the blower being rusted and the snow sticking. Upon further investigation this week I realized the blower is a 451 2.5 gear ratio model and not the needed 450 1.81 gear ratio model. My question to you all here is what can I do to convert the blower and tractor combo to work.
I know the later model 1862 had a 6" pulley, is that something I can change to from the 4.6" pulley without any problems?
Or could just change the two gears in the gearcase on the blower as I haven't been able to locate a whole 450 gear case?
Have any of you used the Xtreme PTO clutch if so would I be able to use the model built for the later 1862 on my early 1862?
Also not trying to break the bank here only paid $500 for the GT two mower decks and the blower 😀.
Thanks for any help you all can give.
Old 02-12-2019, 04:19 PM
Gompers Gompers is offline
Easiest thing is to swap the PTO to a 6". Should be a bolt on replacement as long as everything else is stock. They are the same engine and everything else mounts the same.
Doing this means that the decks that came with it will also need the bigger pulleys unless they also happen to be from newer tractors as well, or else you will spin them too fast.
You can convert the blower to a 450 with different gears, but the gears are NLA and somewhat difficult to come by. Otherwise you need to swap the whole gearbox.
Old 02-12-2019, 11:25 PM
Thank you for the response. I've ordered a later model PTO from Houtz. Will worry about the pulleys on the deck after winter is over here. Glad you brought that to my attention. Again thank you!
Old 02-13-2019, 12:12 AM
Good luck! The 451 does a nice job when it’s set up properly. Power steering is nice with that big honkin blower hanging off the front too.
