New chick from Indiana
Hi I'm new here. From southern Indiana. My father has collected Cubs for as long as I can remember, and has passed the tradition on to me. I have 6 of my own, and my dad has 6 of his own. I have alot of work ahead of me with most of these Cubs, found most at an auction, and they definitely have seen better days.
Welcome to OCC!
sit and sip,n' read. A wealth of info here as well as service manuals, tips, specks ect.. Most all your questions have been answered here by others before you even ask them. Pictures are appreciated. |
Welcome to OCC......
Welcome to the forum.
1985 782 1974 Allis Chalmers 712S 1955 Allis-Chalmers WD45 |
Don B, USAF 1962-1968, Ft. Wayne, IN |
This is my 122. I'm having some issues right now with it. It will crank but not start. It has a new coil, condenser, points, battery, plug and coil wire. plug and points are not getting spark though. I'm at a loss here.
Welcome to OCC. Are you getting 12v to the coil when the key is on?
Sometimes you need to "deglaze" new points. However, first, Buy a cheap 12 volt test light and test for positive at positive post of coil during start. If present, next step is, While starting, probe negative side of coil while starting, test light should flash. If it stays on constant, points aren't closing properly, if light is not on at all, coil is open or points aren't opening properly and coil needs to be replaced/points adjusted. Let us know your findings.
Btw how did you set points? Need to use "static timing" method and not just gap them.
Glad to have you. As mentioned, there is a wealth of knowledge here, and some pretty good folks. Well, the majority anyway.
Make the best of each day , Todd Original's Face Lift thread.http://www.onlycubcadets.net/forum/s...ad.php?t=34439 (O) Start to Finish video.https://www.youtube.com/watch?v=GAoUNNiLwKs Wheel Around videohttps://www.youtube.com/watch?v=XUL-m6Bramk They can't all be turn key! |
Tim, yes it is getting 12v. Just bought a new battery to insure it.
