#311
Sweeeeeet! What kind of implements are you planning to use?
#312
Hey! I just got a great idea! You could unbolt the hydrostatic transmission from the cast iron axle and install a hi/ lo range selector and then put the tranny back on in front of the hi/ lo selector; and then you will have a 2 range hydro!!!
#313
The front remotes will be for my power angle blade and the rear remotes for my dump trailer.
Adam 1964 Model 100 w/ K301 12hp and custom hydraulics 1972 Model 149 turned 129 w/ K301 12hp, triple hydraulics, 66 series clone |
#314
Got front remotes working today. Had room to mount them below the toolbox. I already had a couple of hoses that just happened to be the perfect length.
#315
Dang, I love that trailer...
#316
Now I definitely want to change my 4 to red with white now, lmao!
#317
Got a pic of the piece that holds the couplers. It clamps around them and bolts to the frame.
I also made a new filler panel around the levers.
#318
A few weeks ago, I decided to get the tractor out of hibernation only to find that it had a flat front tire and a dry gas tank. The tank had sprang a leak where I repaired it when I repainted it. Apparently, JB Weld isn’t a long term fix. This time, I soldered the pin hole shut. It’s very odd that it has what appears to be a rust hole yet the tank is completely rust free inside where the hole is and the steel is rock solid around the hole.
The tire had a leak at the bead and since I needed to break down the tires to put tubes in, I decided to narrow the wheels and repaint them. The Firestone 3-ribs don’t have the beads inset from the sidewalls like all other tires I’ve seen, so the bead area of the wheels appears to stick out past the sidewalls. I’m hoping that narrowing the wheels 1” will look better. While the wheels were off, I also added tapped holes for fake lug bolts. I’m gonna paint the tank, wheels, and wheel weights this weekend.
#319
Nice work. Could I borrow your trailer ? :-)
#320
Well, I just read this whole thread through from start to finish.
All I can say is "Incredible and congratulations!" The patience , dedication and skill to pull this off is obvious and it has held up really well too. You must get a lot of pleasure out of just looking at your work. For sure others do! |
Thread Tools | |
Display Modes | |
