My lift arm build,,,
I never bent this lift rod!! and,, it is adjustable,, |
But that does look gucci.
125, 127, 2x IH 682, 2x IH 782, 2084, 3225, 2x3240 |
so, tension, compression, no concern the rod is built heavy enough,,, I guess the rod could double as a crow bar,,, |
For that long of a rod, it really should be in tension vs compression, IMO.
reminds me of the time I was dragging a heavy rigging chain @ work. Boss asked, why are you dragging that chain? I said, "it's plum too heavy to carry, and pushing it didn't work out well" |
that’s awesome!
1912 with Kohler M18 engine repower, CI rear, 50C deck, 364 snow blower IH Cub Original with deck #2 cart GREEN 314 with integral sleeve hitch, H2 and independent brake upgrade from a 317, and front hydraulic blade, 48" deck |
I like that idea. I might give it a try. I will have to straighten the rod out again which might further weaken the bar, but it’s worth a shot. And if it fails again I could always do that on the replacement. The factory bend did not withstand the weight of pushing when the blower was all jammed up with slushy wet snow. It was really my fault, but my plow tractor is out of commission and I had to get the driveway cleaned before the arctic freeze came in. That’s the first snow I’ve had trouble moving with the 551, but understandably so considering how wet the snow was.
Here’s what I did. I straightened the bar again, and I used the angle iron idea. I hope the bending and straightening twice didn’t weaken it too much.
A63D4813-2B11-4231-9C3E-C7B1CB965572.jpg 0A1C994C-D69E-4808-AF6C-6224581A65A6.jpg
Can you use the helper spring for the 450-51 style I had one and helped get it past center
