Got 1864 running
Had some warm weather so I had a chance to work on the non-running 1864. Not done with it yet but did get it running, here is a list of what I did to it;
1-took starter completely apart, cleaned and lube it. 2-replaced broken key switch and broken PTO switch. 3-replaced battery cables. 4-changed engine oil and filter. 5-Drained old gas, filled with new 6-replaced fuel filter and air filter. 7-rebuilt carb (it was so gummed up I had to pry out the needle). 8-changed trans fluid and filter (fluid looked like milk, will probably change again). It seems to run good, power steering works good and lift works. The only thing I noticed is when I move the directional lever too quickly, I hear a slight clunk in the trans axle. When I move it slowly there is no noticeable noise. Should I be concerned about the clunk? Thanks Greg |
Check the bolts that attach the rear end to the frame.( above the axle in back)
and the ones in front of it, they are known for problems. The front ones sometimes break the housing. Extreme makes braces. |
Thanks for the info on the mounting bolts I will check them.
Greg |
Some tips for you to read up on.
https://www.onlycubcadets.net/forum/...ad.php?t=33244
Thread Tools | |
Display Modes | |
