I believe the conversion kit is p/n 24 755 307-S and it should come with instructions, but it's pretty straightforward, but tedious. Gotta pull the engine, pull the blower housing, pull the coils, pull the flywheel and then put it all back together with the new parts. You don't need much other than standard hand tools (1/2", 9/16", 8mm, 10mm, I think 13mm...maybe 15mm), and maybe a feeler gauge for the coils if you're not comfortable using a business card to do it (I always use a feeler gauge). A torque wrench if you're fancy (I always try to be fancy). You could get it done in an afternoon pretty easy. Yup that's very very common. The material they used for the taillight housing wasn't very resistant to gasoline, and guess what's on that fender?
125, 127, 2x IH 682, 2x IH 782, 2084, 3225, 2x3240 |
Is this in Lynchburg?
Yes, this is in Lynchburg
And I was wrong on the price when I checked back this evening, I've been looking at too many lately. He is asking $950 for everything which is much more reasonable, buy the mower and get all the other stuff thrown in. We have agreed on a price and I pick it up on Friday. Very excited; |
If you need to replace a coil, though, you'll need to replace both of them as well as the flywheel since Kohler doesn't make those coils anymore, I wouldn't trust a used one, and the problem is just as likely the box as it is the coils. Other things to keep an eye on: vacuum actuator for the PTO, worn plastic bushings in the pedal linkages (I generally replace them with oilite bearings), the left rear taillight (we already discussed), leaking gas tank bushings for the fuel pickup and for the low fuel sender (It's a horrible design - plan on replacing this every few years. Use some fuel resistant sealant on the bushing as well and let it set up before filling the tank all the way. That seems to help), breather tube cracking (Kohler had this issue for a while...there's an updated part with new material. I don't remember if it was an issue on that spec engine though), diff lock cable free movement/make sure it's not engaged all the time, and then the obvious leaking rear ends both from where the plate seals and the bearing blocks. I think that's the obvious bad things I've found on that design. 950 seems decently fair, tbh, with a low hour one that's mechanically sound. You should probably be able to get $200 - $300 out of the bagger alone if you're not going to use it. Once you work the bugs out of them, they are really great machines. I don't think IH/MTD made a better mower, in the Lawn/Garden Tractor format at least, before or since.
Thanks again for the help and advice. Definitely copy on the bushings, they work good as is but I can feel a little slop in them. Might as well swap them before next mowing season.
I'll read up on the vacuum actuator since I'm not familiar with it. My 3204 PTO switch has always worked so I haven't messed with it yet. I'm guessing the actuators are the same on the 3225 and 3204 which will help. After thinking about it some more I really believe/hope the sputtering at speed and load is fuel pump. It's starts great, idles great, and speeds up nice. Only when at high rpm does it sputtering which seems like it's running out of fuel. When I lowered the throttle speed it would clear up and idle/drive fine again. He has a spare fuel pump so I may start there after checking the condition of the plugs. |
Good point on the fuel lines/filter and carb clean. At that point, I should just pull the tank and flush it as well just in case there is any trash in it.
And get new rubber grommets for the fuel pick up tube and low fuel sensor were they go into the gas tank. I hear they go bad quite often, mine were.
Got it, thank you!
