108 engine with dead tractor attached
How much is a functional 10 hp Kohler on a 108 worth with a non-functional 108 tractor attached? (clutch needs total replacement, tires questionable, various other little problems, all fixable for someone more skilled and motivated than me.) Northern MN.
Cub Cadet 2166 |
cub
I've seen running 10hp motors go for $100. Maybe a little more if the pto works. Mike
Thanks. the only catch is they have to take the tractor too, but hopefully that won't be a problem. I have heard of people paying 200 for IH cubs in my area running or not, but I can't substantiate that rumor
Cub Cadet 2166 |
Its probably a good $2-300 machine if the engine runs, maybe $350 depending on if any attachments or a creeper is present. Clutch rebuild is a relatively simple task and common issue for those more experienced with Cubs.
'70 107 with k301 engine swap '71 106 with 38" deck '70 147R with factory replacement k321, 42" deck '61 Original with 38" timed deck '63 70 "pinkie" 1863 with 54" deck '46 Farmall H, '50 Farmall Cub 105 x2 (parts) |
$100 can go down the tubes rather quickly on a clutch rebuild for parts alone if needed.
Might be closer to $200 on this one. Its kaput except for the pressure plates
Cub Cadet 2166 |
Sold it for 200.
Cub Cadet 2166 |
good on you!!
Thread Tools | |
Display Modes | |
