Exhaust valve freeplay on K-301
How much side freeplay is acceptable on a K-301 exhaust valve? How do you measure? Does the exhaust need more clearance? What harm does it cause if its too tight? too loose? Help me understand, The valve seems new, how do you remove the guide, if I need to go that route? How to install a new guide? I'm not quite sure what the last guy did. I don't want to skimp, I'm not sure about him tho. Thanks guys for all the reply's.
I believe there is a kohler engine manual in the tech section on the site here that will give you the acceptable clearances ,you need a hole gauge to measure the ID of the guide and outside mic to check the valve stem, I personally never replaced a guide and would think that would need done at a shop too much clearance is not good and not enough will cause things to bind up !
