2072 steering problems?
Just picked up a 2072. Not too familiar w/power steering mechanics/operation, of this model. A steering spinner is on steering wheel and after making 180 degree turns most times the spinner/or steering wheel location is different. Sometimes the spinner is on left side, after completing turn, sometimes its on the right, sometimes at the top of wheel. Somethings not right, spinner should stay in same location after making any number of 180 degree turns. Am I not right? The revolutions of steering wheel keep changing while operating through turns. Other than this dilemma, power steering seems to be operating as it should. Thanks for reading/Any suggestions would be appreciated!
That's normal.
I have had four different 2182's every one of them operated like that.
That is because the CC's are hydraulic steering, not mechanical hydraulic assisted like a car.
I appreciate other members explanation. learned something new. Thanks fellows.
I had a similar situation on my 1772. Very poor steering response to steering wheel movement. Worse at lower rpm. I put new seals in the steering cylinder. It is not perfect yet but much better. You could pull your steering cylinder and if there is almost no resistance to moving the piston rod then you are probably leaking oil past the piston.
Thread Tools | |
Display Modes | |
