Greg Rozar AKA- CubDieselFan
Old 09-20-2018, 04:31 PM
Default Mechanic in a can PS fix
Mechanic in a can PS fix. OK let the negative comments begin. Here's the deal the power steering on my 1864/2264 has been getting sloppy to the point that I was planning on pulling it apart and doing the reseal routine to it. Just for the hell of it I bought a bottle of Bars Leak rear main seal repair and dumped it in the tranny. Cost me a whole $8.94. Figured for that huge sum of money what have I got to loose. Well damn after about 30 mins mowing with it I noticed it was getting better, by the time I was done about 3 hours it feels as good as new and the howl is gone. It claims to swell seals so I figured the PS system in these things is nothing but a bunch of O-Rings. Am I recommending this, no I'm going telling you what I did. Now for a long term test to see how it holds up or if it causes any problems.
Old 09-20-2018, 04:36 PM
Know you for as long as I have, I'll say......I believe you Brother Sam.
Roland Bedell
Buy: Made in the USA
Old 09-20-2018, 05:00 PM
Now the other question. Most transmission leaks are the infamous cork gasket. Would this swell that as well and seal it off or will it only work on rubber seals. I think we need another volunteer.
I’m curious Sam. Did you by any chance smell it? Does it smell like it has brake fluid in it?
PS before you get flamed and pissed off, might I recommend pepper in the radiator and banana peels in the differential?
Just kidding, good for you. I’m interested in the long term on this so hope it’s updated in a while!
Old 09-20-2018, 05:45 PM
cooperino's Avatar
I believe it for sure. It makes seals swell. That seals the leaks temporarily because it also softens the seals. Get away with it as long as you can. It works great in a pinch sometimes. I have had the same experience with it... now the other mechanic in a can for knocks lol.. not so much.
Old 09-20-2018, 06:35 PM
I didn't have any leaks to start with just the steering was getting crappy.
Old 09-20-2018, 06:49 PM
cooperino's Avatar
Hmmm. So more like a conditioner. We use to use lucas for that.
Old 09-20-2018, 06:55 PM
DieselDoctor's Avatar
Chemical compounds have come a long way in recent years. Each new idea needs to be evaluated with an open mind. The snake oils of years ago that were worthless have made us gun shy. Personally Sam, I believe your results and hope that you'll keep us posted as to how it lasts. Thanks for sharing.
Old 09-20-2018, 07:03 PM
cooperino's Avatar
Same here Sam. I didn't take what you said as an infomercial. If you say you saw positive results I'm sure you saw positive results.
Old 09-22-2018, 01:09 AM
jaynjeep's Avatar
jaynjeep jaynjeep is offline
Well hey... if it works it works! It will be interesting to see how long it works out.... but you haven't lost anything.. Years ago when an old C6 or TH400 would start slipping or not shifting right we would pour a 20oz coke bottle with half laquer thinner and half auto trans fluid into the dipstick hole... it worked 90 percent of the time... some got 2 or 3 more months.. some got 2 or 3 more years!
Jay
Proud owner of the following:
Old 09-22-2018, 11:04 PM
105_Tom's Avatar
105_Tom 105_Tom is offline
One of my 1872s has the dreaded steering column leak where the hytran comes out the top below the wheel occasionally...wonder if this could add some time before a teardown and re-sealing.....
Tom
105, 149 w/44A, #2 & #4 carts
782 CCC Red w/44C
1512 Smoker w/50C, 450 Blower
2072 w/60" Haban
IH/Lawnboy 3322 Pusher, Scag TT 61"
JD 455, X495, Kubota 2150, Gravely 450, 812
