Greg Rozar AKA- CubDieselFan
Old 07-19-2019, 01:56 PM
Jimbr549 Jimbr549 is offline
Unhappy 1641 won't go-go!
My 1641 suddenly won't go fast in forward and will barely move in reverse. This rig has always been a climber, I have a very hilly 6 acres that it mows weekly, and several trails through our woods as well. Now, she won't climb the grades.
It's not an engine issue, there is no strain on the engine when climbing, it maintains just as it always has. I've checked the linkages and I've checked the fluids.
Could it be a plugged up Hydro filter? I put a new OEM filter on it last September.
Any suggestions appreciated!
Old 07-19-2019, 02:23 PM
V30crewcab V30crewcab is offline
might be time to change the fluid and filter again. is the brake pedal coming all the way up? sometimes that will hang and make it not move much. what about your cv joints, do you grease them now and then? sometimes the splines can strip where the shaft goes in also, but that would not move at all then.
1782, 1862, 1440(sold), 89 1050, 128, 70, some run some don't!
72 scout
IH 404 tractor
Old 07-19-2019, 05:26 PM
Yep, she's greased. I just went to my local CC dealer and bought a new filter and hydro fluid, so we'll see what that does.
Old 07-19-2019, 06:17 PM
sorner's Avatar
sorner sorner is offline
Could be stripped splines on the input shaft to the hydro
1912 with Kohler M18 engine repower, CI rear, 50C deck, 364 snow blower
IH Cub Original with deck
#2 cart
GREEN 314 with integral sleeve hitch, H2 and independent brake upgrade from a 317, and front hydraulic blade, 48" deck
Old 07-19-2019, 06:38 PM
See part #3. Rivets work loose and limit hydro travel. Eventually break. Later handles were welded.
https://polr.partstree.com/v1/iplima...O2k6MTAwMDt9fQ
Old 07-19-2019, 07:10 PM
sorner's Avatar
Oops. I didn’t read the OP carefully enough. I had that happen once where the rivets went loose.
#2 cart
Old 07-19-2019, 07:45 PM
Default Solved!
Replaced the hydro filter and fluid, she's ready for the race track. I searched the old for any nefarious substances, but didn't see or feel anything, so should be good to go.
Thanks for the replys!
Old 07-19-2019, 09:59 PM
good deal. I almost completely lost reverse in my 1782 yesterday, then realized the tunnel cover had come loose, the back had moved over and was keeping it from going in reverse! gotta love the easy fixes.
72 scout
IH 404 tractor
Old 07-19-2019, 10:46 PM
Easy fixes FTW!
Old 08-04-2019, 09:39 AM
Unhappy Well, that didn't last long.
So, after changing the filter and hydro fluid, the 1641 worked great for about 3 hours. Now, she's back to sluggish. Something is clogging the filter, I suppose.
Any suggestions on where to start looking?
