LTX1050 Kohler 22hp starter can't overcome compression and stops rotating
2009 LTX1050 22hp Kohler.
The starter tries to rotate the engine but stops on one cylinder's compression stroke. The engine also seems very hard to turn past this point by hand. Turning past the hang point by hand and engaging the choke seems to help it a bit, but on one of the cylinder's compression strokes it will still try to stop even after the engine gets some rotational momentum. The closest thing I can think of that seems similar to my symptoms is "hydro-lock" The battery is 5 days old, the charging system is working and it looks like the starter itself is new. All electrical connections have been cleaned, connectors removed and contacts cleaned well, battery connections checked and contact cleaner spray for electronics has been worked in to the ignition switch. This was the reason I took the gas tank out, so I could get to the connectors and get the stuff out of the dash to work it all over. Are there any known pattern failures that match these symptoms, or maybe someone has a diagnostic chart? Thanks |
Thread Tools | |
Display Modes | |
