#31
#32
Your throttle and choke cables aren't mounted proper in the clamps.
#33
Thank you for that picture I appreciate it.
#34
You can disassemble the fuel shut off valves and clean them out with a couple drill bits by hand.
#35
Now would that be an issue with my throttle? Machine seems to run fine just idles a little low. Sorry if this is a stupid question.
#36
Idle speed is set with a screw on the side of the carb.
#37
Thank you for the picture, I set the cables correct so i get full sweep of the throttle and choke. The choke is fine but the throttle is weird. It idles fine and if i start to move the lever it barley makes a change till i hit WOT then it seems to be fine. No misses or sputters at WOT this seems to run amazing and happy. |
#38
Still need to move the throttle clamp up so that there's more travel (earlier) in the throttle cable.
61 and 63 Originals 123 (2) 782D 106, 147, 122 102 parts It's only original ONCE!
#39
That's not it either though. The cable is physically pulling the lever but the butterfly in the carb isn't moving. I'll pull the air cleaner off and get better pictures tomorrow.
#40
Sounds like the governor is out of adjustment or sticking, It looks like there's a bit of rust in the pics, something may hanging up.
