#21
They're good filters, no problems with them (The Purolator version, that is)....except THEY DONT FIT ON OUR HYDROS!!!!
1992 Cub Cadet 1440 1,400 hours, 44'' Deck, 42'' IH Dozer Blade, Light Bar, All Trail tires, 16 year old Cub Cadet owner! |
#22
That Mopar filter is probably an oil filter...the hydro takes a HYDRAULIC filter. They are not the same. Use the OEM, NAPA, or WIX filter.
#23
yeah DODGE the MOPAR
Id stick with a good hydraulic filter too. But the stackable iso mounts id keep.
the lock washers could reduce vibration... |
#24
Those were flat washers that they had put on the bolts because they were too long and they bottomed out in the oil pan but they still werent tight. I got some shorter ones to put in it. Im going to get a good hyd filter to put on it and change the fluid
Original, 100 with fenders creeper lights 3pt spring asst., 147 with electric lift IH hubcaps, 102, 126, 682 QA36 snow blower, 2 Dozer blades, Haban sickle bar, John Deere 60 Lawn tractor with deck and snow plow, 1962 Fordson super major backhoe, 1941 Allis Chalmers WC |
#25
Oh Boy
Well this is something I see a lot and wonder why de do dat!
It also has some funky wiring
#26
How is this for a hydraulic line fix??!
Just picked up this 149 this past weekend and this is what I found under the tunnel cover from the previous owner!! |
#27
Did someone call a plumber?
#28
That's what I thought Lew when I pulled the tunnel cover off!!
#29
I have always been kind of partial to the 149's.
Tell you what Eric, I will drop the 149 off and pick up your 582!!! |
#30
I got this 125 today...
Hows this for a choke location? He also bent back the bottom of the tower so he can get his hand in there.
