Greg Rozar AKA- CubDieselFan
Go Back   Only Cub Cadets > Resources > What is it worth ?
Old 05-11-2017, 05:50 PM
Originally Posted by sorner View Post
I agree totally with that last paragraph. I think a lo boy is too big for my needs, and not much benefit. It's not going to work for ground breaking duties. It would just be a mower, and maybe a snow mover. I think maybe for now the best thing for my needs is what I currently have. Letting a deck ride on the wheels probably wouldn't work here because some spots of the land aren't exactly smooth. My 1864 with the 48" deck can handle it as well, I can set the deck where I need it and go without riding on the wheels if I need to. One thing I've noticed about that deck is if I get into anything too high the output gets clogged up, I think because the support bar across the underside of the deck at the opening seems to catch longer clippings and cause a backup. My ford deck had one of those and did the same thing so I cut it off and now the grass flies out of it with no restrictions. I don't want to do that to the Cub 48" deck.
Thanks for the good advice...
Yeah, that deck bar gets in the way. I'd cut it out if it was mine. You can always weld one back in if you needed to.
Oh, the Lo-Boy will work ground just like a Cub Cadet would. It will pull a 16" moldboard plow. I'm not interested in mine because of it not having a rear PTO, and I need something that is larger for row crop work. The Lo-Boy is too wide to straddle just one row, and too narrow to straddle two. Plus, it won't pick up my 2 row IH cultivator high enough to be able to use it.
Old 05-11-2017, 09:21 PM
sorner's Avatar
sorner sorner is offline
Maybe I should see one in person. It is hard to judge the size from pictures. I have a brinly plow and cultivator for sleeve hitch and my Jacobsen is perfect for that. I don't think a bigger tractor would work for that.
Old 05-11-2017, 10:06 PM
sorner's Avatar
Actually I looked at my deck more closely, and that bar is bolted in. Even better yet... It's "Cub Cadet 703-3511B-0637 Guard, Finger". I don't regularly stick my fingers in there so I don't think I need a guard for my finger. I think I can do without it.
