#21
i measured the spare belt i have MTD 954 3075 3 times and each time i came up with 77 7/16" aprox 77.44 if taking the outside measurment is correct that is over a inch smaller than the dimensions you gave me. that would make the differance.
#22
#23
Thanks for the video, i tried all the methods except the string and came up with 77 5/16 to 77 7/16 multiply times.
When my CC dealer and i measured the belt we had a couple of years ago i remember it matched the info he had but i don't know what that was and that belt was extreamly tight also. Should i contact MTD and give them all the info i have and see what they come up with. |
#24
"B Section V-Belts are measured on the inside diameter." B75 - B-Section V-Belt (5L780) 5/8 X 78 B76 - B-Section V-Belt (5L790) 5/8 X 79
#25
At this point you have 2 options.
#1:Continue using the short belts. #2: Get a belt 1" longer. and it will go on easier, and problem solved. You will keep your shorter belt for an emergency spare. Using too short of a belt causes excessive wear on all drive components, including but not limited to, belts, pulleys, bearings, idlers,etc. and causes you aggravation with removal/install. |
#26
i really don't know where to go from here except to get a longer belt, i am confused and really appriciate all the help and input.
No matter how i measure the belts i have (954-3075) they measure aprox. 77.4" both ID & OD which makes no sence to me i would think the OD should be larger than the ID. But the conclusion i have come to is the belt appears to be aprox. 1" smaller than it should be at 78.6". With the information provided on this forum i am going to seek a resolve (belt length) from MTD. Thank you so very much for your help |
#27
Thread Tools | |
Display Modes | |
