Greg Rozar AKA- CubDieselFan
Old 08-30-2020, 12:54 PM
Brannon Brannon is offline
Default Blades disengage/engine & engine cutoff
I have a XT1 with the 50 inch deck. Since the summer started, the blades would disengage with no rhyme or reason. Usually, when the blades would disengage, the best way to get them to come back on would be to push the blades knob back down, reverse briefly, and pull the knob back up. This would work essentially every time. I have an acre and this would happen about 6 - 8 times during the job. Sometimes the blades would just simply disengage and engage for a brief second without going through the routine.
Last weekend, I noticed the engine begging to cut out, but coming back to life right before it fully shut down. This weekend, this became more prolific with the engine exhibiting this several times until it finally cut off completely. I could not get it to restart.
I'm thinking this might be the ignition switch, but not sure. I'm hoping some here, with more experience with this mower might direct me to the likely source of the problem.
Thanks,
Brannon
Old 09-01-2020, 05:22 PM
guyina4x4's Avatar
guyina4x4 guyina4x4 is offline
3 year warranty
Otherwise wiring
Look over with a fine tooth comb
JD x475
Old 09-02-2020, 07:49 AM
ironman's Avatar
ironman ironman is online now
When you say you "could not get it to restart" do you mean it would crank as normal but just not fire, or do you mean you turned the key to start and no cranking at all??
Old 09-03-2020, 07:29 AM
No power, as if the battery was dead. However, the battery shows good voltage.
Old 09-03-2020, 08:22 AM
Am wondering about a safety switch going in and out. Like a seat
safety?
Ken
Old 09-03-2020, 10:43 PM
safety?
Ken
I was wondering the same as well. I messed with it and it didn’t seem to have an effect, but that doesn’t mean that isn’t it.
