Thoughts on Stacks
What's everyone's thoughts on stacks? Do they serve any purpose? I've heard that they reduce the amount of noise but some say it makes the louder. Anyone have any past experience with one?
Well, you've got an Original. I've got an Original with a stack. Definitely makes it louder, not quieter, though that could be because it's just a cheapo TSC muffler. Benefits are, I can wake everyone up at 8AM with it, and I get an exhaust cap .
My 107 also has a stack which is just the stock muffler with an extra 45 degree pipe extension that it allows it to be positioned vertically outside the hood. IF it wasn't already a rotted out rusty muffler, it might be just as quiet as it would be in it's stock position, but it's still loud anyway. Not that I mind, though, I personally like the sound. However, with any exhaust stack on an IH Cub, you'll want to build an extra support to keep weight off of the exhaust port on the engine. With excess weight and vibration on it the port can crack. Neither of mine have supports yet but I really need to make them at some point.
'70 107 with k301 engine swap '71 106 with 38" deck '70 147R with factory replacement k321, 42" deck '61 Original with 38" timed deck '63 70 "pinkie" 1863 with 54" deck '46 Farmall H, '50 Farmall Cub 105 x2 (parts) |
Stack puts the exhaust in your face.
And the noise closer to your ears, neither which are good.
Big tractors had upwards stack to direct sparks and heat away from dried vegetation. Otherwise, some people think it's a cool factor. I'm not privy of a bong producing carbon monoxide.
Two 125's and a 124 all with 42" decks Plow blade #2 Cart QA36 snowthower |
I think shorter vertical stacks can look pretty cool on the pre-Quietline Cubs, but to me at least, nothing says tacky like an 82 series with a sawzall cut in the hood/side panel for a crooked stack to come out of.
'74 IHCC 108 - 38" triangle, supersteer axle '87 CC 1872 and 1811 - Haban, 44C '96 CC 1863 - 54GT '79 JD 400 - 60" deck "Projects" '67 123, '65 102, '71 126 |
The Cub Pack. 70, 100 (creeper), 104, 122 (2), 1250, 1810, 1863, 2182, LTX 1050, SLTX 1050, SLT 1550, SLT 1554, Snow Chuckers 450, 451, 826T, 1030E, 2 plow blades. always looking for "just one more" |
A "lady" once told me that a "stack" on a small tractor, advertises the operator has "masculine deficiencies" he is trying to make up for.
