Carter Carb Question on C-26
On my K-301, I have a Carter C-26. If you take off the screw that holds the fuel bowl on there is, in the center threaded section a brass fitting, that looks removable with a straight screwdriver. What is that fitting called, purpose, should I remove and clean? What if I mess up the screw slot, if its original a d tight? Brass fittings can be a bear. Any thoughts and suggestions are greatly appreciated
Thread Tools | |
Display Modes | |
