I will try the puller first if my local autozone has it in the store, but if it don’t work..... but if it does come off with the puller I’m still left with damaged threads that I doubt could be repaired with a die
Just hoping it won’t be this stubborn, iv taken steering wheels off of other cubs without a problem so hopefully I can get lucky again but we will see
If the wheel won’t come off the 1100 then I will just have to deal with the awful steering for the day and hope nothing breaks
Well, Good luck to you. Take your time with it.. Soak it real good with the best penetrating fluid you can get "not WD-40" Soak it over night if need be and be patient with it.. Try to avoid smacking with hammers.. You will get it!
Thanks for the confidence boost! I will spray it with pb blaster right after work and let it soak till the morning
The best penetrant I've found is a 50-50 mix of acetone and automatic transmission fluid. Seems to soak in and soften better than commercial products. hth
http://www.onlycubcadets.net/forum/i...d%20Hand-C.JPG Yup.. what he said.. works great.. ATF will shine the hell out of faded red paint also
Grease it before you do anything.
They have a grease zert on them Ya know. May just be dry! |
Don’t have anything to mix it in that won’t be destroyed by the acetone but I have been wanting to try that mix
It’s full of fresh grease, thanks tho
