Greg Rozar AKA- CubDieselFan
Old 11-17-2021, 01:50 PM
SwimmerRob SwimmerRob is offline
Default Runs, then dies
My new, to me, 2166 (600 hours) runs for 15 minutes at mid throttle, then dies.
It will start again within about 5 minutes, then runs for about 5 minutes.
It will keep up this pattern indefinitely. I've noticed that the initial run of 15 minutes has lengthened (from about 10 minutes to 15 minutes) as the temperature outside has gotten colder, which makes me think it may be a coil.
The gas is new. I've blown out the fuel line in both directions. I've cleaned the carb bowl, replaced the fuel pump, fuel filter, and spark plug. I've loosened the gas cap.
I'm thinking that since the pattern is so consistent that it's electrical rather than fuel-related.
I'd appreciate any help.
Thank you!
Old 11-17-2021, 02:00 PM
cooperino's Avatar
There is a possibility that you Magneto "coil" is failing. I have had them do similar things like what yours does, However generally all of mine took a lot longer than 5 min to come back to life.
Is there a low oil shut down switch on that engine?
Old 11-17-2021, 02:04 PM
Welcome to OCC.......
Sounds like it could be a Fuel Delivery issue.
Roland Bedell
Buy: Made in the USA
Old 11-17-2021, 02:06 PM
cooperino's Avatar
Was thinking would be first thing I would investigate also but the OP comments that he cleaned system etc.. But who knows. Could be crap in tank still.
Old 11-17-2021, 02:16 PM
Could be a float or Fuel Pump issue.
Roland Bedell
Old 11-17-2021, 02:19 PM
cooperino's Avatar
Easy enough to check... When it dies crack it open and see if fuel comes out..
Hopefully the OP sees this before spending money
Old 11-17-2021, 02:30 PM
Roland Bedell
Old 11-18-2021, 09:00 AM
I'm guessing it's electrical, too. The pattern seems too consistent for it to be fuel. I've replaced the fuel pump and I've been through a few tanks of gas. Is the Magneto "coil" the SAM? Can I test it with a multimeter before I remove it?
Thanks!
Old 11-18-2021, 09:18 AM
IF.........everything is original, then the 2166 rolled out of the Factory with a Kohler CH16S-45509. If you like, I can send you the CH Service Manual.
Roland Bedell
Old 11-18-2021, 02:19 PM
guyina4x4's Avatar
guyina4x4 guyina4x4 is offline
Does it have spark after it dies?
When it won't restart.
JD x475
