Thick Carb Base gasket 18 hp?
My tractor is an 1863, (143-664-100).
I have ordered a reman carb. They sent it with a thin gasket. gasket.jpg I need one about 1/4 inch thick because the throttle link hits the manifold before WOT. Reason I know it is that thick is I stoled one off my other 18hp kohler Do I make a spacer or is there a gasket available? Is this it? #3 on parts list Link:https://cc.shankslawn.com/oemparts/a...20/fuel-system Gasket, Carburetor KH-24-041-07 KH-24-041-17 |
According to the Cub Cadet Parts Lookup Site, you will need Base Gasket (#3) which is KH-24-041-17.
You could cross reference if we knew the Model & Spec number on your Kohler Engine.
Thanks R Bedell for fast response.
I am in the process of making a spacer plate. If that is it. That will save me time. 1863spec.jpg plate.jpg Thanks |
The Kohler web site says: KH-24-041-17-S.
Basically the same as the CC site.
Just Ordered one.
Thanks for your help. |
That gasket is not a 1/4" unless you get two.
Thanks
It will be here Friday. I guess I will just make that spacer. |
Thanks R Bedell
The Gasket arrived today. It is the thick one I need. 1/4 inch was a ruff guess I was 0.080" shy This is the thick gasket I need thou, Maybe this will help someone else. Picture with thickness and part# carbgasket.jpg |
Thread Tools | |
Display Modes | |
