#51
If you used the mule drive from the 50C (The part with the pulleys) that's your problem, the 50c driven pulley is offset so the mule pulleys are set at an angle. This is the mule for a Haban, you'll notice the pulleys are straight in line with the driven pully on the deck.
#52
1912 with Kohler M18 engine repower, CI rear, 50C deck, 364 snow blower IH Cub Original with deck #2 cart GREEN 314 with integral sleeve hitch, H2 and independent brake upgrade from a 317, and front hydraulic blade, 48" deck |
#53
Sam, nailed it.
5F0266B9-6B69-46B1-85FF-F99226DD9B38.jpg The one installed: A566CD70-8F8B-4C36-8CA3-D830CA7CAF4C.jpg
#54
It sure is nice when you have all and the correct information.
#55
So good that there are people that have experience.
you owe Sam a 6 pack So much for my non experience with a 60" deck mule drive. Do check the pulleys for wear tho' ---the belt must have been getting hot as well as the mule pulleys. You just might be able to run that 60' deck yet! I ran into that angled/ non angled mule drive situation on a 50" deck while swapping it between a 1650 and a 782 not to mention the pulley width difference, but it was quite obvious looking at both of them together |
#56
Thanks Sam!
#57
Glad you got it working, that Sam is a knowledge machine.
Thread Tools | |
Display Modes | |
