Greg Rozar AKA- CubDieselFan
Old 08-09-2018, 08:09 PM
mfeldmann mfeldmann is offline
Default 1914 super whining noise
I have a 1914 Cub Cadet that has a high pitch whining noise. After 2 years of use I decided to change the rear end fluid. I used Cub Cadet hytrans and a Cub Cadet filter. On startup tractor has a high pitch whining noise. Sounds like it's coming from the engine but I know noises travel. I cut 2 Acres of grass twice with it to make sure any air bubbles would be out. But it still makes high pitch whining noise. Any ideas out there would be helpful thank you.
Old 08-09-2018, 09:19 PM
cooperino's Avatar
Was there any noise before you changed the fluid?
Old 08-10-2018, 01:57 PM
FrankF3's Avatar
FrankF3 FrankF3 is offline
I had a very loud whining noise when I first got it. While it was whining I accidentally put a downward pressure on the top of the tunnel cover and the noise stopped. Looking at it further some of the screws for the tunnel cover were loose allowing it to turn into a sounding board. Snugged the screws up and it was quiet as normal.
1989 - Cub Cadet 1772
38" Lawn Sweeper #196483
60" Haban Mowing Deck #196374
Old 08-10-2018, 04:35 PM
No, there was no whining noise before I change the filter and fluid. Everything works fine except for this high pitch whine.
Old 08-10-2018, 04:50 PM
Chad126's Avatar
Chad126 Chad126 is offline
Can you elaborate more? "whining noise" is a bit hard to define.
Is it quiet or loud? Can you idle down and hear where it is coming from better, or does it vary with RPMs? Is it continuous or does it stop/start when you engage pto? Do you have attachments on it when it is "whining"? Does it sound internal or external? Do you hear it when it is parked, or when you are moving?
Hyrdo setups are generally noisier. Perhaps you know this, just stating a point. Again, how loud is it?
Help us help you.
Another note... you say you think the sound is coming from the engine and it started after changing Hytrans. Are you thinking they are related?
"Equality is about giving everyone an equal chance, not about giving everyone an equal result."
1971 126 w/ Brinly Sleeve Hitch, Plow, Discs, and Cultivator
http://www.onlycubcadets.net/forum/s...ad.php?t=50159
Old 08-10-2018, 05:02 PM
How about a video uploaded to Youtube (or wherever), and linked here. Amazes me when people want us to diagnose things that require seeing, but don't post pictures, or want us to identify a noise we can't hear.
Hey, what sound am a making right now?
Old 08-10-2018, 05:14 PM
TNTs CC TNTs CC is offline
Errrr…
3240 870hrs - 48" 289 deck, front hitch, 3 hyd circuits, 54" blade w/hyd angle, 45" 2-stage snow blower, Sims cab, 5 42# suitcase weights and 70# rear wheel weights
GT3204 207hrs - 48" 289 deck, 45" 2-stage snow blower, 54" blade and angle cylinder
3204 580hrs - 48" 289 deck - Parts Tractors - 3208 560hrs (rusty) 3 hyd circuits, 3pt hitch, 44" deck - 3165 rust free roller
1650DH 54" blade, Xtreme cat-0 3pt, 44" deck, filled 23x10.5-12 Tru-Powers
Old 08-10-2018, 07:13 PM
bllwnkl's Avatar
bllwnkl bllwnkl is offline
Randy
1976 IH Cub Cadet 1250, 1978 IH Cub Cadet 1250 W/Hydraulic lift
Old 08-10-2018, 11:09 PM
Does a smell go with the sound?
Old 08-11-2018, 07:46 AM
How did you drain it? Did you use the drain plug near the suction tube and possibly knock it loose or crack the tube somehow? If you did drain it from there, could there be a lot of gelled up moisture that got sucked into the filter on start up? I like to drain them from the back and clean the inside real good but if your machine still has all the cat 0 & rear pto stuff it is time consuming. Is the oil foaming now?
Thread Tools
Display Modes
