Greg Rozar AKA- CubDieselFan
Old 01-14-2023, 11:24 AM
1711Cub's Avatar
1711Cub 1711Cub is offline
Wink
I cleaned the new replacement dipstick and painted the visible end Cub Cadet yellow. The end of the original dipstick broke off presumably years ago.
582, 682, 782, 782D, 1282, 1050, 1210 x 2, 1711, and 1811
Old 01-14-2023, 12:02 PM
I think red would have been a better color. You are missing the spark plug seal IH-117160
Up to 530 and counting...
Old 01-14-2023, 12:24 PM
1711Cub's Avatar
Thumbs up
Good eye. That part is on order.
For posterity, KH 47 313 01-S is the Kohler part number for the spark plug seal.
Old 01-14-2023, 06:33 PM
Farmall450's Avatar
I paint mine black, either flat or semi-gloss. Best match to original.
But 1711 makes his look like a Command, which is fine too.
Old 01-15-2023, 03:37 PM
1711Cub's Avatar
Thumbs up
Refinished both front wheels
Old 01-15-2023, 06:18 PM
You can put the Cyclops bearing caps on those, all you need is the large washer if you are so inclined to do so.
Old 01-24-2023, 08:07 AM
1711Cub's Avatar
Thumbs up
NOS Kohler seal 47 313 01-S:
New deck wheels:
Old 01-24-2023, 09:34 AM
zilla24's Avatar
zilla24 zilla24 is offline
Look great, what paint did you use?
CC Tractors: 1650, 1200, 800, 149, 125, 86, 782D, 2072, 1572, Original
Old 01-24-2023, 12:29 PM
1711Cub's Avatar
Smile
Rustoleum Almond
Old 01-24-2023, 11:38 PM
Club Cadet Club Cadet is offline
When I repainted the front wheels on my 1810 I went white on the outside and black on the inside. Not OEM, but the inside was usually stained with dead grass and excess grease from the steering knuckle anyway.
