Rear Axle Brace
Sorry for resurrecting this thread, but I have an 1862 that I recently installed the Xtreme GT rear axle brace (cc-99-003) on. Everything installed easily and fits great! I was wondering if the single bolt on top and bottom of the front of the brace could still allow forward and backward movement of the rear? Or is it’s main purpose to eliminate frame twist? I would think it should have 2 bolts on top and bottom or be welded together. I’m plowing snow with my cub so I’m just making sure this rear is indestructible.
Sorry, my pic uploaded upside down.
First, welcome to OCC.........
Next, I rotated the images for better viewing. Lastly, I started a new thread for you. Good work on your project.
The 4 bolts that go through the axle tubes and attach the rear to the frame keep it from moving fore and aft. The tractor doesn't have enough traction or power to cause any damage as it is now.
Thanks for your quick responses! And thanks for designing this brace, Sam! Does the brace effectively “bulletproof” the aluminum rear ends? Does this make it as robust as the earlier cast iron rears? Have you seen any failures with the brace on? I’m plowing snow with 75 lbs wheel weights and 200 lbs of suitcase weights on a rear weight bracket.
Relax, nothing you can do will hurt the case short of putting a huge amount of weight on the tractor and that would break the axle tubes. Go plow snow and be happy.
Load the rear tires, put some wheel weight's on it and some good tire chains and have fun. Me I hate plowing snow.
