Greg Rozar AKA- CubDieselFan
Old 05-14-2021, 12:21 AM
Ambush Ambush is offline
Default Ags, Fluid and Extra Weight.
The Carlisle Tru Power ags came in and on to the rims. Nice looking tire, but pretty stiff. I bought a fluid fill valve off Amazon and several jugs of RV antifreeze. I have a five gallon bucket with a garden hose attachment that I use to run anti-freeze into my inboard boat motor, so I figured I'd just try to gravity feed the fluid in. It worked great actually. I measured enough fluid into the bucket for a 75% fill and just went about doing other things.
I had a few 14" diameter, 5/8" thick plates, so I turned them into additional wheel weights. With the fluid, the IH weights and the plates, I added 108 pounds to each tire. I went and tilled up some sod on some slope and the tractor climbed through it way better then with the turfs! Can't wait to try it with the loader bucket!
Old 05-14-2021, 10:52 AM
Shuuda cut a hole in the weights in case you need air.
Up to 530 and counting...
Old 05-14-2021, 05:46 PM
jbrewer's Avatar
jbrewer jbrewer is offline
When...
61 and 63 Originals
123 (2)
782D
106,
147, 122
102
parts
It's only original ONCE!
Old 12-27-2021, 03:33 PM
Farmall450's Avatar
Looks great. I might load up the 1811 rears if the chains/weights aren't enough to handle the #450 blower well.
I'm not sure how much 2-3 gallons (roughly the weight of a IHC cast weight I suppose) will help. Or how much even fits in the 12" rims.
