Greg Rozar AKA- CubDieselFan
Old 06-18-2019, 07:19 AM
DL127 DL127 is offline
Default Cub Cadet 1210 questions
Does the Cub Cadet 1210 have a cast iron rear axle and hydro unit like my 127 or one made of aluminum? If it is the aluminum one is it durable?
Old 06-18-2019, 07:37 AM
Rrmarti's Avatar
Rrmarti Rrmarti is offline
Now I am fairly new to the cub cadet line, but I have a 1210 and mine has an aluminum rear end. That being said, I believe that the 1210 started with a cast iron rear, then ended production with an aluminum one. As for the durability, I have read that the aluminum rear end is durable enough. I guess it all depends on what you plan on doing with it. But i will let some older more knowledgeable guys confirm this all.
Old 06-18-2019, 09:26 AM
The 1210 was built by CCC/MTD. It never had a Cast Iron rear end.
Roland Bedell
Buy: Made in the USA
Old 06-18-2019, 10:05 AM
I'm not positive it is a 1210 because the paint and decals are gone or faded. The owner is going to send me a photo of the rear axle this evening. I'm gonna try to post the 2 photos I have, perhaps someone can give a positive id.
Old 06-18-2019, 10:26 AM
gsomersjr's Avatar
gsomersjr gsomersjr is offline
I don't see a gear shift so it's not a 1050 or 1204. Manual lift deck and single cylinder engine almost guarantees it's a 1210.
Current: 86 102 122 1810 1862 1864 SZ60
Past: Original 71 72 73 100 102 122 123 124 125 127 129 147 149 169 383 582 682 782 782D 784 982 1000 1050 1100 1200 1210 1250 1415 1420 1440 1450 1535 1641 1650 1710 1711 1730 1806 1810 1811 1860 1861 1862 1864 1882 3185 3205 7265
Old 06-20-2019, 09:52 PM
V30crewcab V30crewcab is offline
my 1210 is aluminum rear, and its an early one with points ignition.
1782, 1862, 1440(sold), 89 1050, 128, 70, some run some don't!
72 scout
IH 404 tractor
Old 06-26-2019, 09:38 PM
sorner's Avatar
sorner sorner is offline
It's aluminum, but if you really wanted cast iron you could easily swap it with one that has external brakes, maybe even one with internal brakes too.
1912 with Kohler M18 engine repower, CI rear, 50C deck, 364 snow blower
IH Cub Original with deck
#2 cart
GREEN 314 with integral sleeve hitch, H2 and independent brake upgrade from a 317, and front hydraulic blade, 48" deck
