Old But Still Going Strong
I think my little grinder was my grandpa's. It's been around as long as I can remember. It has the old, oil cap bearings.
I was at an auction 30 years ago and they had this big grinder. Nobody would bid on it. I said $5 and took it home. It runs on a flat belt and weighs 300 lbs. I made belt guards for both of them. |
That's pretty cool! One on the left is like one my grandpa had, it's around somewhere. Looks like the big one will grind just about whatever you want. It's cool you got to get a piece of of your family's history.
Brian April 1979 1200 Quietline 44A deck 1988 1211 customized into a 1288 with a K301AQS 38C deck and a 1864 54” deck . Snow blades 42" and 54" . Brinly disk, brinly plow a cultivator and a $5 brinly yard rake! |
You guys are killing me, a lot of my equipment is flat belt driven.
Grinder, Lathe, drill press, shaper. Geese, it ain't that old --or is it? |
Are the belts on this equipment attached to a big wheel outside with water running over it?
The south bend Lathe was built in 1918, and was converted to use a model "A" ford transmission for speed selection. Was lucky enough to purchase it from the original owners nephew, over 50 years ago, it does what I need to do. That old equipment was built in different times, with different thinking. Sure as heck not light duty/throwaway. |
I'm guessing my big grinder was made for a line shaft because the motor mount has been added on.
I've often wondered how well that works. Do you get any slippage under a load? |
They aren't really "old", just from a time when things were built to last. I bet a lot of those perfectly good tools got thrown away when people got talked into "newer is better".
