149 implements fitting a 127
Howdy. I am going to be getting a 127 this week to keep my 149s company and was wondering if the 149 implements would fit the 127. The 127 has been "modified" a bit so I have some work to do finding the real parts that go to it. Thanks, gardentoys
The 127 is a narrow frame and the 149 is a wide frame, plows and mower decks will work on either with the correct sub frames.
Which implements are we referring to here? Belly mount, rear mount, and front mount all connect differently. Some could cross and others may not. At least not without the correct adapters.
They won't "fit" right over. As mentioned the sub frames would need changed at least. For example, the front blade won't fit without swapping subframes. You need different mule drives for the mowers. I suppose the rear mount stuff would work, although you'd likely need a different mule drive for the tiller.
So, if you're thought is buying the 127 and simply "sharing" implements, it won't be that easy. The Wide Frames started with the next series, 1x8/9. If you want to simply be able to use attachments on both get another one of those or a Quietline 1x00/50.
-Jason Cub Cadets: 1200 | 149 | 1650 | 122 | Z-Force S 54 Implements: QA42A | Push Blades | #2 Tiller | Rear Blade | 223A Utility Trailer | And a few mower decks Gravelys 5260 | CI Walk-behind (Project) And a couple of Subarus |
Thread Tools | |
Display Modes | |
