Check Cub Cadet, seems like they are different part numbers for axles and tubes, may be different because of studs to hold the wheel on?
http://www.cubcadet.com/webapp/wcs/s...0-A/0031900009
money pit followup
I checked the eBay post. The wheel studs are definitely different. My axles do not have studs. While the studded axles may work, there may be other differences leading to a cascade of unanticipated changes. If I have no other choice in the end I'll go but for now I'm attempting to find exact replacements.
Terry O,100,72,102,123,104,124,105 125,129,149,1200,982 (2)2182s w/60in Habans 3225 |
You can put the later axle shafts in the CI housing, but you have to change the spider gears in the differential. Or swap the diff's. I should have mentioned that you have to stay with CI parts or AL parts depending which you have. |
My 982 is pretty low number 6xxxxx and it has alum tubes and a cast center housing. Don't know if that was OEM or not.
SN break for the switch was 719,999. |
