1450 Refresh - wanted to share and lessons learned
This isn’t anything extraordinary as many of you have done complete frame off resto’s and/or engine rebuilds and other major mods but this was my first big dive into the 1450 and I wanted to share, plus things I learned which may help someone else who finds this. Really glad I didn’t sell the tractor when I first took it out of hibernation last summer. From an investment standpoint- time and $ I probably put in more than what it's worth :: but learned quite a bit. I pulled the engine and did the following:
Results:
Major things learned:
Anyway, thanks for everyone’s help here, definitely provided guidance. Nice 606 + lock washer on steering box Due to cradle mod and angle of front frame to cradle bolts hard to get in, but is managable with crowbar and some tweaking to get thru bolts started Engine hoist made job easy- though I had to use a hook from ratchet strap to access the engine's hook |
Nice work partner!
You done well, sharing with the group, and to prove that the Quiet line and it's inherited problems are a fast and ready fix, making the tractor what it should be, King of the Wide Frames! I'm stoked!
IH CUB CADET 1450, 72, 86, 1211, IH #2 CART, IH 56" SNOW BLADE, COLLECTING CUB CADET ENGINES |
Very nice job!! Getting my steering tight is one of my next main goals. After looking at all the great threads here, I dont know whether to feel inspired or intimidated haha!
Great job on the quietline. Since I bought my 1650 loader tractor, my first quietline by the way I have learned of all of the problem areas and have been slowly fixed them. It is amazing what the cradle mod and new ISC mounts will do for them.I have tightned up the hood hinge and added split rubber tubing to the rear hood support and it really quieted down the rattles. I might just learn to like this tractor. Keep up the good work.
Tom |
Always consider a cast iron oil pan.
Doug Dad's 122 w/42" cast deck, spring assist, lights,weights, rear lift 1250 w/hydraulic lift, lights,weights, spring assist. 50C deck converted to an A with front wheels 44C deck converted to an A with front wheels. QA-36A 42" blade |
Great job and keep up the good work!
Allen Proud owner of my Original! My Grandpa's Cart Craftsman Lawn Sweeper Craftsman Plug Aerator |
Thread Tools | |
Display Modes | |
