Kohler K321 Deep sump pan
Will the deep sump oil pan bolt holes line up in my Cub cadet 108 frame.Where these are solid mount and if im right the K321 is an iso mount from a quiet line and will the sump fit down through the frame.The pan in it is a flat style pan on the K241.
Current tractor my son and i have 1991 wheelhorse 520h 60"deck 48"snow blower w/ onan 20 hp 1980 whelhorse b-82 need restore 1976 simplicity 7116 all restored waiting for a new motor (my sons tractor) 1967 sears super 12 (my sons tractor) 1972 Cub cadet 108 restored w/ complete motor rebuild 5 years ago |
A deep sump oil pan from a Cub Cadet 149-169 is solid mount in the frame. It will bolt to your frame and your K241 using the same holes.
I would get a different connecting rod if your are planning to use the deeper pan on an engine that has a shallow pan. You need the longer dipper that is the bottom part of the connecting rod.
Project Uncle Dick Cub Cadet 70 http://www.onlycubcadets.net/forum/s...ght=Uncle+Dick |
Thanks the new motor thats going in is a K321aqs and it has a deep sump and yes i bought the rebuild kit for the 14hp and it has the long dipper.I was more or less building the 14hp and was concerned if the motor mount holes where the same.For some reason i thought the 149 was iso mount but thanks for setting me straight.
