Greg Rozar AKA- CubDieselFan
Old 10-14-2012, 12:22 PM
mrcubcadet's Avatar
This friend called me & he gave me a used roll of .035 wire. No brand on it but its not HF. I did some stick welding 42 years ago & far from being any good. I changed the wire over to .035 & with my 1/2 hour of a welding experience I noticed a difference from the .030 that came with the unit. I welded ( played around) some 1/8" flat stock, 1/4" black angle iron, about 20 min., worth. So now I have 45 min., worth of welding.
As a bottom line the .035 seemed to flow better than the .030.
I'm going to purchase some & just junk the one from HF.. I think the guy told me its cost is about $ 11.00 or so? But with what he gave me I think I have enough for 5/6 projects. That will git'er- done?
Nik,
Good to hear, as I will eventually try .035...
I have about half a spool of the original HF brand left, but I think I will continue to use it up, and just grind my 'not the best' looking beads down, until it's gone.
-105___ Tiller
Old 10-16-2012, 11:44 AM
nikster's Avatar
nikster nikster is offline
I had a choice of 2 different wire's from the same company. One was $ 9.98 & the other was $ 19.98 both .035 wire. I found an expert at the place who told me what the difference was & to go for the BETTER wire, he said that I'll notice the difference right off.
Well with my 40min. of ever welding with the unit I indeed noticed a smooooth flow as compared to the cheap wire that came with the unit & the wire my friend gave me. He gave me this wire cause he also went with the better $$ wire. Less splater & less junk to chip away.
So, as an end result its well worth it in my humble opinion. Sorta you get what you pay for.
Old 10-16-2012, 07:03 PM
I'm gonna review my Miller 175 tomorrow.
Old 10-16-2012, 08:22 PM
nikster's Avatar
I would?
But the cost for me does NOT JUSTIFY my 5 welding projects. Heck im ahead of the game in that I dont have to haul my projects to a welding place,
& prob., never have to use a welder again. Im a TOTAL NEWBIE with this stuff. :
Nik,
Old 11-20-2012, 08:51 PM
BigB87's Avatar
BigB87 BigB87 is offline
I'll tell ya wat. i bought my welder from HF and its done wonders for me. its saved many of my mowers from being parted out (not cubs), ive fixed my decks on my cubs with it and it does great. i found out if ya use Hobart flux wire in it they weld a bit better. I used it to make my weight bracket on my 86 for when i pull my plow and when i mounted my winch on my trailer. good welder for the price. im satisfied with it
Brandon
CC models: 86, 1650, 100 w/hanban sickle mower & 1872
1972 86 w/12" brinly plow & 65lb wheel weights & 42" grader blade
1978 1650 Hydrostat w/44" mower & 42" IH push blade
1965 100 w/hanban sickle mower
1989CCC 1872 w/50c mower
Old 04-08-2013, 01:58 PM
sawdustdad's Avatar
I normally try to buy really good tools. I've found that they pay for themselves in longevity and ease of use. I'm very much a welding amateur, but I've had and occasionally used a Sears 240A stick welder for 35 years. Departing from that wisdom, I bought the HF 90A unit based on suggestions here. It works OK. Needing another welder for the other shop, I decided to try a better unit, so I got a Hobart 140 Handler reman unit. (~$400 from Amazon, free shipping). Added a bottle of 25%CO2 ($200) and this unit is sweet. Nice clean beads, almost no spatter, no porosity. what a difference $500 makes.
