Greg Rozar AKA- CubDieselFan
Old 07-26-2021, 08:35 PM
MSS7120's Avatar
MSS7120 MSS7120 is offline
Default 2185 HDS axle seal question
I added the 2185 from my dad to my livery yesterday. He gave it to me and was happy that it is a dry tractor, that is it doesn't leave a puddle on the ground after sitting. I loaded it up and noticed very slight dampness around the left axle housing. Got it home and the left axle seal had blown out on the ride home. HyTran all over the trailer deck. I parked the tractor on a side hill to minimize leaking.
Has anyone replaced this particular seal? Part number 921-3020A, Number "5" on the chart. Looks like i have to remove the right hand axle subhousing by bolts number "7" and slide the assembly off then remove snap ring "5". Then remove the axle assy and replace the seal. Smear gasket sealer on the mating surfaces and reassembly. Let sit for 2 days and fill.
Am I missing something? What part is the axle splines fit to? Part "30" or "32". Is this just a simple slide fit?
Any ideas tips or tricks are appreciated.
https://www.ccparts.com/cub-cadet-pa...85-4152-162208
Mark from Minnesota
3165 with CC Snow Blower, Front blade, Sims Cab
3185 with 3pt hitch, it runs now. But not well.
48in and 52in mower decks
2185 with mower from my dad when I have a project for it.
Massey Ferguson Model 70 corn planter.
CC yard cart
Old 07-27-2021, 05:25 AM
I've not done that on a 2000 series yet but that looks correct. Here is the link to the free manual and it explains it on page 5-88. Good luck and take some pics for us.
https://www.mymowerparts.com/pdf/Cub...epair-Manuals/
Old 07-27-2021, 07:13 AM
ironman's Avatar
ironman ironman is offline
The axle splines will slide into the splined differential side gears.
Note that the book makes a big deal out of re-installing "new" snap rings.
Old 07-27-2021, 03:02 PM
MSS7120's Avatar
Thanks both. I'll order a new snap ring as well.
Mark from Minnesota
CC yard cart
Old 07-28-2021, 09:19 AM
Looking at the parts diagram, I'm wondering if you can pull the axel by just removing the snap ring on the outside that holds the seal and bearing in the axle tube without pulling the rear and axle tube off the rear? If it was me I'd give that a try first.
