K301 engine bore scoring
I pulled the head on my newly acquired 127 and to my dismay the engine was scored really bad and it obviously was not running . The piston is not stamped on top std, but i think it is not been bored. I tried to show how deep the grooves are, but about + .045. the last picture is a .045 spark plug gauge wire buried
20210714_203931 (Custom).jpg 20210714_204012 (Custom).jpg 20210714_204044 (Custom).jpg 20210714_204217 (Custom).jpg I think this will need to be bored and put a sleeve in it for a std piston. I read a couple places of boring them to 3.5" but I don't think I want to do that. My thoughts are that it got water in the cylinder and rusted the pin to the side or corroded in that area and then ran for a while. It got pushed to the back for later.
Steven __________________________________________ 127 NF, spring assist, 36" IH Danco BB-36 snowthrower, 42" mower deck. CW-36 snowthrower, 42" NF blade. QA42A blower, 126,127,149,1720. |
Wow!
That is a nasty looking bore for sure. Good luck with it |
I'll second that !
My goodness !
O M G...............
Ya it's bad, but I've seen worse in engines, Yes it can be bored/sleeved back to Std, and be as good as new if done by a reputable shop.
Something I'll mention as I am not up to date on the cost of a sleeve repair: Since that is not a one- of-a kind, high dollar value engine of historical significance, a lot of times one can find an identical engine block either in good shape or easily machined .010 over and go that way. That engine can become a parts donor. It is not the first time unknown problems are discovered. What your plans for the tractor are, will direct your wise financial decision. |
Thankfully I was able to measure it with my primary cylinder bore measuring tools.
I've seen engines get sleeved only to have the whole cylinder break off and be totally junk , I'd find another block ....be a lot cheaper in the end
I would think that event would be on a thin walled cylinder.
it was a k series someone posted on here a couple years ago or so.
