Greg Rozar AKA- CubDieselFan
Old 10-19-2018, 12:53 PM
CubCadets CubCadets is offline
There's also a 1282 near you for $100, you should start by picking that up.
You are a patient man! I agree at least picking up the 1282 bewould be a good idea before starting a different project!
Old 10-19-2018, 01:27 PM
Mudrig150 Mudrig150 is offline
I know the sheet metal won't work, but darn it, I'll make it work.
The 1250 will really be a work horse then.
Old 10-19-2018, 01:55 PM
Slightly off topic, but...
So I''m building a mini hay wagon off an existing 2 axle trailer chassis, and I was wondering... For the fronts I want tri rib 4.80x4.00-8s, and for the back the 16x6.50 8s. Which would match better?
These V61s or these other tires?
Old 10-19-2018, 02:09 PM
It's just a wagon, get whatever is cheapest.
Pap's 100
Restored 108
1211 Dual Stick
1050
Old 10-19-2018, 02:11 PM
Unless you plan on putting a super rearend in it it won't be any different than a regular 1250. The rearend on a super has different gears to accommodate the larger tires, the big tires on a standard rearend will rob torque.
Pap's 100
Restored 108
1211 Dual Stick
1050
Old 10-19-2018, 04:04 PM
Terry C's Avatar
Terry C Terry C is offline
Every hay wagon we owned had the same tires all the way around. So did all our wagons.
Terry
O,100,72,102,123,104,124,105
125,129,149,1200,982
(2)2182s w/60in Habans
3225
Old 10-19-2018, 10:46 PM
john hall's Avatar
Dang, ya'll was quite fancy! Every real hay wagon is a hodge-podge of old truck tires!!! Well we did have 2 Deere's with factory flotation tires. Still have one of them and the tires are still good after 40 years (it doesn't see the highway anymore). The other wagon is an Oliver or an Electric, its probably on its 3rd set of mismatched tires. When its 95 outside all I want to know is are we done yet?
2072 w/60" Haban
982 with 3 pt and 60" Haban
1811 with ags and 50C
124 w/hydraulic lift
782 w/mounted sprayer
2284 w/54" mowing deck
Old 10-20-2018, 12:33 AM
I'd take it off your hands Tim. YOU know the saying, "bullchit walks, money talks"...
Old 10-20-2018, 08:47 AM
I finally found it.
Old 10-20-2018, 09:07 AM
Oi, I'll figure sometin out, don't you dare!
