Help, 2016 LT50 stalls
I bought a used LT50. It has 120 hours on it. When I got it it was surging. Went through the typical tune up routine. New fuel, fuel filter, plugs, cleaned the carb and changes the oil. That did not fix the surging so I replaced the carb with a Kohler OEM carb. The engine now runs well. When I idle down too quickly, I will get the occasional backfire. My problem now is when I start cutting the mower will run for a few minutes then die. I have to shut the key off wait a moment and start the mower again. When I do start it it cranks a bit before it turns over. Then I can cut for a few more minutes and it will stall out again. The cycle repeats. I have not noticed it stalling without the PTO engaged but some further experimenting needs to be done to rule that out.
Dose anyone have any ideas where to start? |
First, welcome to OCC.......
Sounds like your Carb is set too lean. Adjust it to a richer setting.
Possibly a clogged tank, or plugged screen in the tank? You are describing a lack of fuel condition. Does it have a fuel pump? ( I'm not familiar with an LT50) I don't understand you saying it "cranks a bit before it turns over"?? "Cranking" is the process of the starter turning the engine over and then the engine starts and runs under its own power, Ideally. Cranking can be done with a rope, hand crank, or starter motor, depending on the application. Is the starter turning over but not rotating the engine?? if so, then you prolly have an over running clutch problem with the starter pinion, or the starter pinion is not engaging the flywheel, ( they tend to get dry of lube on the shaft where the pinion slides. Oh, backfiring is also an indication of a lean condition. If you have a main jet adjustment it needs to be enrichened a 1/2 turn. ( most newer engines do not provide main jet adjustment for environmental reasons) |
Thread Tools | |
Display Modes | |
