Greg Rozar AKA- CubDieselFan
Old 05-10-2023, 01:57 PM
Check your reverse and seat switch. Those are the 2 that must be closed for the relay to stay energized.
Old 05-10-2023, 01:59 PM
dachtera's Avatar
dachtera dachtera is offline
Heh. -- Those were bypassed years ago by a previous owner.
Old 05-10-2023, 10:49 PM
Do you have a schematic for you tractor? You will need to check your reverse relay.
Old 05-11-2023, 04:20 PM
dachtera's Avatar
Looks like the switch or the PTO clutch. It want's to blow the in-line main fuse if I try and flip the switch up and hold it, so the clutch was working. Would be nice to simply bypass that switch for a simple on/off since the rest of the safety stuff is long gone.
Thoughts?
Old 06-27-2023, 03:09 PM
dachtera's Avatar
Default I have steering!
I just wanted to say THANK YOU to Oak and the others who pitched in and provided much-needed information to get my seals replaced. It took a second attempt to see what I messed up originally, but I've been mowing leak-free a handful of times this spring and the steering is working great. Even seems to have a bit less 'drift' from side to side.
THANK YOU AGAIN~
Tim D.
- Cub 1872
- Bobcat S850
- Cushman Turf Truckster
Old 06-28-2023, 04:55 PM
Gary C Gary C is offline
I think that is an impulse switch that activates a latching relay. By hold it on you are continuously energizing the coil for the relay.
Old 07-05-2023, 09:06 AM
dachtera's Avatar
Any thoughts on a currently available relay? I cannot locate the factory/original part-number online anywhere (ebay, messicks, partstree, etc)
Tim D.
- Cub 1872
- Bobcat S850
Old 07-05-2023, 10:32 AM
1711Cub's Avatar
1711Cub 1711Cub is offline
Lightbulb
For the relays, see this thread:
https://www.onlycubcadets.net/forum/...362#post521362
You didn't mention what serial number your 1872 is, but a 1989 1872 uses a 725-0894/925-0894 relay.
Equivalent to Standard RY-11, Echlin AR108, GM 2072624, Delco D1751, Kem AR161, Four Seasons 35765, BWD R367, Wells 56-1683, Duralast 19811, Santech MT0512, JD191K16.
