#31
Make the best of each day , Todd Original's Face Lift thread.http://www.onlycubcadets.net/forum/s...ad.php?t=34439 (O) Start to Finish video.https://www.youtube.com/watch?v=GAoUNNiLwKs Wheel Around videohttps://www.youtube.com/watch?v=XUL-m6Bramk They can't all be turn key! |
#32
My 1650 new fan lifespan was about.....5 minutes! I didn't put the cover doing a test drive and some plastic fly away. Since I only use it for snow removal I never replace it but if someone came up with a rubber one I can mod to replace the crappy cheap OEM high density plastic one I don't hesitate one second to do it. Better be safe then sorry.
Gilles. 1988 2072 401 54" hyd angled blade 1988 1872 364 snowblower/C50 deck 1976 1650/QA42A blower/44A deck/standby 1976 1450TS/Sleeve hitch/44A deck/in storage 1963 100 (red)/in storage 2010 Kubota 2380-2/42" infinity deck (engine swap) |
#33
#34
#35
As I get to know my 'new' 149 I've discovered a number of broken items.
One of which is the cooling fan -- it still has one blade on it or I probably wouldn't have even realized there should be a fan there... My cooling fins were completely caked in solid crud. I used a plastic scrapper to clean them off... I've been mowing my ½ acre this way at full throttle and it takes me an hour since I'm new to this... I've also been hauling several loads of #57 gravel around the yard (400lbs a load) all before I knew the fan was broken/missing... Far as I can tell, it runs fine without it... Owning a Scout I know IHC didn't put the fan there just to spend money so I WILL be replacing the fan at my earliest convenience... I like the idea of this "rubber fan" that was mentioned being available from a Cadet dealer. Anybody know if these are still available or a part #? |
#36
I will say something that I do not think was covered when this thread was current. My feeling on the matter is this. Cub Cadet built tractors to be really tough, hard working, animals in ANY ENVIRONMENT. So, that said, one guy mowing a half acre in a average climate more than likely would never need that fan. VS a guy that is say tilling or plowing acres at a time in a really hot dusty climate? He may really really need that fan. These little tractors we love were over built. Probably why we love them so much.. Designed to last and last. So the "do you need the fan question" Im a fan of the fan.. IH put it there so I like it! lol
#37
Ambient temps have been in the 70's to 80's while mowing and moving gravel. I've driven IHC Scout II's for over 20 years now -- I got the Cub 'cause I didn't want a "throw-away" machine. Mostly I knew how much I'd hate doing any maintenance on a throwaway machine... I do have an IR temp gauge so maybe I'll post some #'s before and after mowing tomorrow! I guess the next silly question I have is should I break off the one remaining blade? I'm used to working in a world where that kinda imbalance would be catastrophic so visually, the thought of it in there bothers me... I have also left the 3" x 5" cover/insp plate over the pump off figuring that can only improve airflow... |
#38
same thing happened to my 129, had it running while rear was on stands, I was adjusting neutral position of the trunnion, new fan, new pins, new driveshaft, had tractor back together all of ~10 minutes when something fell into the fan and busted a blade. so I have all but 1 at the moment, when I took it apart initially I think all the fins were missing, and yes this one was so badly coated with crud, that if I didn't know any better I'd have not known it even HAD fins.... so yeah I gotta get me another fan for this thing.
#39
I don't know anything about a 'rubber fan'. I do know that a new OEM fan is much more flexible. They get brittle when they get old.
I'd replace it asap. It's easy to do. |
#40
Now I know this is not much help,-- but I stuck a thermometer in my rear end once,
Oh my, I mean in the hydro fill hole on my 782 and mowed 3 acres one summer day, there is a pix of it somewhere on my 3000 + posts, but thinking it was about *150 or so. That was with a good fan and the hydro fins clean. |
Thread Tools | |
Display Modes | |
