Greg Rozar AKA- CubDieselFan
Old 09-06-2018, 10:10 PM
SLS327 SLS327 is offline
Default Gear quality
Tiller and snowthtower gears..are those hardened teeth from factory? Anyone know the the specs on the gears 15, 20, 30 tooth?
Steven
__________________________________________
127 NF, spring assist, 36" IH Danco BB-36 snowthrower, 42" mower deck. CW-36 snowthrower, 42" NF blade. QA42A blower, 126,127,149,1720.
Old 09-07-2018, 06:46 AM
Good question, but I think only the IH Engineers are going know that answer.
Roland Bedell
Buy: Made in the USA
Old 09-07-2018, 07:25 AM
Gears are made from a tough steel, then they usually are case hardened.
They are not hard all the way through, or they would be brittle.
And to answer your question, yes they are factory hardened, or they would wear quickly.
Just a quick google for you here:
https://www.engineersedge.com/gears/...ring_13180.htm
Old 09-07-2018, 07:41 AM
That's what I was going to say. If they weren't hardened there wouldn't be any left 50yrs later.
Pap's 100
Restored 108
1211 Dual Stick
1050
Old 09-09-2018, 03:57 PM
I do agree with the gears teeth being hardened too. Ive been looking for a stock set of aftermarket, not much luck finding ones with the correct hub projection, but really close. Thanks for the input guys.
Steven
Old 09-09-2018, 04:40 PM
Watch ebay, the gear boxes show up from time to time.
Just remember to get the right ratio, for either tiller or thrower.
Some sellers don't know what they have.
Old 09-09-2018, 06:31 PM
jbrewer's Avatar
jbrewer jbrewer is offline
George , you're a treasure of info! Thanks for taking the time to share it in such a friendly way.
61 and 63 Originals
123 (2)
782D
106,
147, 122
102
parts
It's only original ONCE!
Old 09-10-2018, 11:20 AM
You won't find an aftermarket gear set. I spent a lot of time looking, and I know where to look.
What you will find, are good used gears, and some new available. I wish I could remember who it was who built the attachments for IH, but I don't. Whoever it was, built them for others too. The John Deere 33 tiller was made by the same company, as was their snow thrower. Both use the same gearbox. Again, you have to watch the ratio, as they differed from the IH set. That I am aware of, there are at least 3 different gear sets out there. As I recall, Deere can get the small gear still, but it's expensive. Interestingly enough, IH used the same gearbox on the Cyclo Air planters to drive the seed drum. But it is NLA. I'm betting there are other applications of that gearbox that I have yet to find.
