Greg Rozar AKA- CubDieselFan
Old 11-27-2020, 09:31 AM
gkingbing gkingbing is offline
Default Trash can solution
After spending way too long manually hauling trash and recycling containers out to the road this simple solution popped up the other day. Using just some 1/8" flat aluminum and a few pop rivets the task is now much easier, just in time or the looong upstate NY winter. Although the brackets could have been permanently fastened to the blade I chose to make them slide on and off with a pin to secure them. Heavier metal would be a plus but I have no welding or bending equipment. Happy hauling!!
Old 11-27-2020, 09:40 AM
Cleaver idea. I like it.
Roland Bedell
Buy: Made in the USA
Old 11-27-2020, 11:10 AM
longislandcubs longislandcubs is offline
Definitely a good idea...
Old 11-27-2020, 07:41 PM
Did you test them full including any Raccoons?
Up to 530 and counting...
Old 12-05-2020, 12:53 PM
Default Testing
LOL, They have not been tested full, including Racoons. I hope to see if they can handle the weight this weekend. I just saw an ad for low temp welding rod that will work on any metal using a Mapp torch. I may choose to rebuild these things with thicker metal if the rods actually work.
Old 12-05-2020, 11:02 PM
IHCubCadet147's Avatar
Good idea, let us know how they work out.
Old 12-09-2020, 08:37 PM
Great idea! How are they to see around when driving? Possible to put in the back with a 3 point and a bar? Would also add more weight to the rear for better traction in the snow. I like your creative thinking!!!
Old 12-16-2020, 09:02 AM
No problem viewing where the cans need to go.. There are no obstructions. Between the wheel weights and calcium filled tires there is plenty of weight in the rear. I can hardly lift the weights or tires. The tires never lost traction while moving heavy snow. That will be re-verified tonight with the 2 + foot of snow predicted.
