Greg Rozar AKA- CubDieselFan
Old 08-08-2018, 09:06 PM
Billy-O's Avatar
Billy-O Billy-O is offline
Most likely a bowel gasket is leaking, or the bowel nut is.
The typical Lew.....farting again!
Plow blade
#2 Cart
QA36 snowthower
Old 08-08-2018, 09:25 PM
What you eat from yer bowl winds up in the bowel anyway(if your a Regular guy) if not, there is exlax
Old 08-08-2018, 10:17 PM
bllwnkl's Avatar
bllwnkl bllwnkl is offline
I think you can get a suppository for that.
Randy
1976 IH Cub Cadet 1250, 1978 IH Cub Cadet 1250 W/Hydraulic lift
Old 08-09-2018, 09:17 AM
Guy goes to the Dr. claiming he couldn't hear well.
Doc looks him over and says "you have a suppository in your ear."
Guy says "what??"
Doc says, much louder "YOU HAVE A SUPPOSITORY IN YOUR EAR!!"
Guy says, "Well, I guess I know where my hearing aid is now!"
Old 08-09-2018, 10:39 AM
Chad126's Avatar
Chad126 Chad126 is offline
I don't mean this to sounds insulting, but are you certain it is coming from your mower?
Do you have anything else that could be leaking gas in the garage? I would think you would notice the leak when looking at your mower since the smell is that strong.
"Equality is about giving everyone an equal chance, not about giving everyone an equal result."
1971 126 w/ Brinly Sleeve Hitch, Plow, Discs, and Cultivator
http://www.onlycubcadets.net/forum/s...ad.php?t=50159
Old 08-09-2018, 10:59 AM
bllwnkl's Avatar
Good point, a leak should be obviously wet. The fuel goes from the tank to fuel line to carburetor. Should be obvious you would think.
Randy
Old 08-09-2018, 12:31 PM
Steve149's Avatar
Steve149 Steve149 is offline
I have 2 cubs in this garage, a generator, weed eater, and once the tank was purged the smell went away. I tore the carb apart and double checked the float cleaned it up again with carb cleaner and compressed air...there was nothing in it. Reassembled everything and filled the tank there are no leaks. I agree with Jon on the fact that gas evaporates fast but 3/4 of a gallon in 2 days is a bit much. The side of the engine is dry and still dirty if the gas would be coming out i think there would be a definate clean spot where it was running. My 149 sets here minding its own with a half tank of fuel with no issues.
Old 08-09-2018, 01:14 PM
Two days and maybe 2.5 quarts of gas, closed up garage, summer time.... oh yeah. I promise it evaporated.
Look at the air filter. Should be able to see it got wet on the bottom where the gas ran through it. Needle valve may have stuck, or got something in it. It happens.
Old 08-09-2018, 01:22 PM
Steve149's Avatar
Thanks Jon i will check that...your experience on these goes without saying.
Thread Tools
Display Modes
