Greg Rozar AKA- CubDieselFan
Old 08-05-2018, 11:17 AM
Looks great Uncle L. Right up my alley. Uncle A always say patina equals personality. Assuming it’s going to get the LP treatment of a new clutch disk as well while the en-gyne is out? Nevermind I see that the one in it now doesn’t have the window in the block.
This thing has your name all over it then, I will drop it off at your dads when I see him.
The earlier editions of the 70 models had the C-block 7 hp Kohler engines in them, so you can C the inards of the engine. They also came out with the C-series seats, by the Seymour Bunz Co. So, Uncle Lewy, looks like you will either be mowing tomorrow in your "back to nature" suit or your plumbers outfit! Nice pick-up Unc. Since it is the C-series 70, I hope you got it for the characteristic Uncle Lewy's 1 C-note price!!!
Great find my friend!!
Thank you! Is Seymour Hiny related to Mr. Bunz?
Originally Posted by Dirty Steve View Post
Cool looking tractor Lew. How is the deck? Any rot or holes?
None that I can see, I will remove it and check out the bottom to see if the hoopy thingys are still there.
Up to 530 and counting...
Old 08-05-2018, 02:18 PM
Nice find Lew. You always sniff out the good deals.
That old 7hp going to be for parts? I need some of them. Seriously.
Old 08-05-2018, 09:05 PM
So I got a look see at this, wiring harness is questionable, roll pin is broken by the GDR.
Brakes work, and it does have a decent deck, missing parts of the baffles though.
It was hot today and the pool was calling so I took a break.
PM sent JB
Old 08-05-2018, 11:21 PM
jaynjeep's Avatar
jaynjeep jaynjeep is offline
Nice looking tractor Lew!! I really like the 70/100's.. they are dirt simple but rugged and reliable.. easy to work on.. and on top of all that they have good lines!
Jay
Proud owner of the following:
Old 08-06-2018, 08:04 AM
jbrewer's Avatar
jbrewer jbrewer is offline
Very nice. I'd for sure fix and use. Great patina!
61 and 63 Originals
123 (2)
782D
106,
147, 122
102
parts
It's only original ONCE!
Old 08-06-2018, 09:40 AM
Congrats on the 70, Lew!
Proud owner of my Original!
Old 08-06-2018, 09:43 AM
Thanks Guys,
The worker Lew ';'
Old 08-07-2018, 07:37 PM
I got this to run today, no smoke, the roll pin was not broke but the clutch needs some attention. ';'
Old 08-07-2018, 07:59 PM
mortten mortten is offline
Imagine that.
Doug
Dad's 122 w/42" cast deck, spring assist, lights,weights, rear lift
1250 w/hydraulic lift, lights,weights, spring assist.
50C deck converted to an A with front wheels
44C deck converted to an A with front wheels.
QA-36A
42" blade
Old 08-20-2018, 12:14 PM
Last week I spent some time fixin' stuff the get it to be a worker. Starts on the first revolution, putt putt putt putt...
Serviced the clutch.
Replaced the damaged PTO lever.
PTO works now.
Did a little rewiring and now the battery charges.
It was missing the S/G.
Put in a used key switch instead of twisting the wires together.
New points, and plug, 55 year old condenser still working.
Replaced the muffler.
Unfroze the front steering knuckles.
Fixed the leaky tank, put a sediment bowl filter on.
Cleaned and put a new kit and throttle bushing in the carb.
Replaced the froze up choke cable.
Drained the trans and replaced with hytran from the 1512.
Still need a shifter knob thingy.
The deck I replaced two rusty outer pulleys, and idler. Blades were still sharp.
I reused the old belts as they look like they were replaced.
All parts I got from the used parts store, except the clutch disc, a guy I know had a used one.
Now the 70 is a turn key tractor.
Thread Tools
Display Modes
