Best tires for pushing snow
So last year was the first year i tryed to push snow with my 1512. I had no traction, right now ive got old turf tires (probably the originals very worn and hard), Chains helped a little but i just put a new blacktop drive in and dont really want to chew it up. Will Ag tires grip better in snow then turfs. or do i just need to load up on weight.
I'd say your only option would be ag tires and a ton of weight. They also sell rubber chains that I've heard mixed reviews about.
I've not ever seen chains on a garden tractor chew up asphalt. Che chains won't leave as big a mark as a blade. If marks on your asphalt bother you, use a shovel.
Once its cold enough for snow to stick the asphalt should be pretty hard. Not likely you will chew it up unless you sit in one spot against a snow bank spinning and spinning the tires. Little scuffs here and there are normal. Asphalt should be sealed once a year after the first year or 2 installed. The sealer helps protect the asphalt. I do mine in the spring and all the scuffs from my plow on my F-250 get covered up.
I put radials on the last GT I used for snow plowing,,
the radials grabbed almost like chains. (the radials were take-offs from a side by side ATV) |
I would not worry about it, scratches are normal.
Chain it up, and plow.
Make the best of each day , Todd Original's Face Lift thread.http://www.onlycubcadets.net/forum/s...ad.php?t=34439 (O) Start to Finish video.https://www.youtube.com/watch?v=GAoUNNiLwKs Wheel Around videohttps://www.youtube.com/watch?v=XUL-m6Bramk They can't all be turn key! |
thanks for staying on topic, ill try a set of Ags and if they dont work live with scuffs on the drive.
https://www.onlycubcadets.net/forum/...=rubber+chains To O.P. check out the two links for discussion on the rubber "chains". Might be worth a try before you invest in ag tires. |
You're going to be disappointed in ag tires if you get deep snow. If I had to do it over again, I'd take cad's suggestion and get some atv radial tires.
Jeff 62 O, 1641, 1864, 1862, 1535, LT1045 #4 cart |
