Saving a 1982 Yellow & White CCC 782
I acquired this Y/W 784 about a month ago when picking up a 1641. Both were headed to scrap, so they threw in this tractor. Sitting 10-20 years (owner got it in the same condition I did), it has the original KT17 Series II.
I was curious why it still has the IH S/N/Model # system, despite being CCC produced in 1982 (I surmised from the 142 in the model). 782 142 U 700455 My immediate plans are to rebuild the carb (once a kit shows up) and see how she runs. Intake manifold and carb were off when I got it. Fuel pump runs good, and I replaced the lines/filter. Engine being somewhat apart I had assumed it threw a rod like most KT17s like to (I had that experience with a Series II in my 1711, too), but it has good compression and doesn't seem to have any extra holes. I did have to get a new front tire, and found a matching Turf Saver to compliment the other side. Short term plans are mounting some R1 Goodyears I picked up and adding a sleeve hitch that was destined for the 1811, but seems like a better fit on the cast rear (saves $80 for the Xtreme tabbed ear U hitch). Jeff should have a Brinly adapter shipping out for me Monday, so outside of fabricating a lift rod to match the one on the 1711 I should be good to go on both of those aspects. An aside, Rustoleum transport yellow seems to match the Iron Guard I used on the 1811 wheel weights last fall (and goes on a lot better/thicker). If it were a bigger project I'd look harder for Rustoleum Marigold.
Why Farm Half When You Can Farmall? 1282 | 44C Deck, Chains, 42" Blade, Cast Weights, 020" Over K301 * 1711 | 50C Deck, #1 Rear Rototiller w/ Extensions, Sleeve Hitch, KT17S Series II 24302 --> CH18S * 1811 | 46 GT Deck, 42" Blade, Chains, M18 Magnum, Sleeve Hitch * 1782 | 60" #375 Deck, Kubota D640 Diesel * 1862 | #450 Snowblower, M18 Magnum * 782 | Y/W KT17 Series II, Sleeve Hitch * 984 | Y/W Onan/Linamar 20HP, Sims Cab, CAT 0 3 PT w/ Rear PTO, 60" #374 Deck |
Some pictures of when I first got it (on the trailer) and how it looked tonight.
That is a super early CCC tractor-probably has the Brownsville Tenn address on the tag, instead of Cleveland, OH.
582, 682, 782, 782D, 1282, 1050, 1210 x 2, 1711, and 1811 |
Almost seems too early to have the Series II?
The KT17 Series I were installed in Chassis Serial Numbers below 726124.
The KT17 Series II were installed in Chassis Serial Numbers above 726125. Obviously, almost all the Series I have been replaced due to failures. They are a rare sight today.
I sold the conversion kit I had back when my other Series II launched a rod. Certainly this one shipped with a Series I, then, but must have been replaced before Magnums were a popular replacement.
The Series I is not rare. There are 82 series cub cadets all over the internet for sale, and not for sale, that still have the Series I in them.
Adrian 2072 (789513) |
Thread Tools | |
Display Modes | |
