1450 and Now what do I do?
Today I thought I would replace the flex couplers on the drive shaft because thay look orginal and I figure it's about time. So I take the 4 bolts out of each end and I can not get the drive shaft out. Do I have to slide the engine ahead or am I missing something? Advise would be appreciated.
Thanks, Chris |
shaft support?
I'm to support the rear of the drive shaft so as to not hurt the pump bearings? Is this correct?
Thanks for the information! Chris |
Yes Chris; thats correct
Gotcha. Thanks again guys.
Chris |
If your isolation mount rubber biscuits are in poor shape now is the time.... and you wouldn't have to drive any coiled pins out.
Just a thought..
Quietlines and narrow frames, mostly projects but I mow with a 1200 and have a 122 set up for pulls. Wandering the country bringing towers to wind farms everywhere, and bringing yellow stuff home to Texas. Also into flatfender jeeps. |
Thanks truckntran but it looks as if the isolator rubbers have just recently been changed. Why they didn't do the flex couplers at the same time is beyond me. I did find the bolts on the couplers to be quite loose and now that I have installed larger washers and snugged up the bolts the tractor is much smoother. I did not tighten the bolts enough to squash the flex coupler.
Chris |
