not starting
Hello guys, well I got the Governor Arm adjusted and everything was working great then it just stalled. I looked in the gas tank to find it empty, so I filled it up and it started again. I parked it in the shed and went out the next day and it wouldn't fire. It turned over like it normally would. I took the plug out cleaned it and tested it for spark and it has a spark. Now I am just lost once again.
Wild Bill is correct....pop the bowl off the carb (while the the carb is still bolted on). see if the gas flows nicely when the float drops.
If not, follow the line back....see if it's coming out of the line first, then the sediment bowl. Where ever it stops...just blow into that area, it'll start flowing after. Makes sense to clean the tank out now. Winter's here..get it done now, instead of when it's 20F out.
Fly Fishing is not a sport...It's a way of life. |
hello guys about to head out to the shop to clean the tank and put the fresh gas i just got for it and check out the carb. thanks alot guys
well guys i was in the shopand i tryed what you guys suggested and i got it to run for a half a second and then blew some smoke and it still wont start ? this tractor is starting to make me and my bank account angry
Is the condensor grounded properly? Check all of your grounds and make sure there is no corrosion.
I like pie |
could it be a faulty condenser? is there any test i can do to see if its still good?
Just got a new spark plug,put it in and it fired up. it ran very rough after i shut it off i took out the new plug and it was all blackened ? i also noticed it was back fireing alot?
Backfireing through the carb or exhaust?
the exhaust
wild bill :I just put new points,a new head gasket,cleaned the carb with cleaner, cleaned all the grounds and adjusted the govner. it was running fine 2 days ago and now it runs like crap
Thread Tools | |
Display Modes | |
