Greg Rozar AKA- CubDieselFan
Old 08-15-2018, 07:10 PM
2wheelsadam 2wheelsadam is offline
Default Box Scraper near or far 😳
I am going to build a box Scraper and was wondering on your thoughts. There is the Brinkley design that has one beam that attaches to sleeve hitch. There is the International 40 design which is very close to back of tractor and attaches at 3 points. My way of thinking is the International 40 design is too close, and would dig in every time tractor hits a hole? And that Brinkley design might be better? Want to know your opinion.
Old 08-15-2018, 09:12 PM
"Brinkley" doesn't build a box blade. Brinly does.... So does Agri-Fab IIRC.
The IH #40 box blade is about 100 times heavier than the cheap Brinly one they make now.
If you want a good one, you should look at the one Gannon made.
If you think you can build one, build it like an IH #40 or a Gannon. If you look, they are made just like box blades for larger tractors. Being close to the tractor isn't going to really make any difference if you know how to operate it. A mounted blade will be affected by the tractor's track PERIOD. If you want a box blade that levels well, and isn't affected (much if any) by the tractor, build a pull type with about a 6' or 8' tongue.
Old 08-15-2018, 09:40 PM
Default Box blade
Where can I see that Gannon made?
Old 08-15-2018, 10:01 PM
Google it.
Old 08-15-2018, 11:57 PM
The close in box is made that way so that you will be able to lift it with a non-hydraulic, manual lift.
The more the attachment is moved away from the tractor, the harder it is to lift.
If you have hydraulic lift, you can move the box back,,, a little,,
even a hydraulic lift will struggle, if you move it back too far.
Build it light,, 1/8" is plenty, no fancy cutting edge, too much weight.
Old 08-16-2018, 05:16 AM
sorry I though it was a members name that built it.
Old 08-16-2018, 05:18 AM
yes cadplan that is a very good point about lifting. Was not even thinking of that point.
Old 08-16-2018, 05:21 AM
There is.
https://www.onlycubcadets.net/forum/...ad.php?t=47572
