As you can see the drain plug magnet was working overtime, so I am going to flush the system out, then refill and probably swap and drain fluid two more times this season.
Metal shavings
I got the looking on the 2140 and see that it is an AGS machine(Auto Gear System). Before you dump the Rotella in there let's make sure it won't damage the clutch system. I'll do some more checking. That was the weak link in these tractors with the AGS drive system, people used the foot pedal like a hydro and it would damage the clutches. You're supposed to select the gear and hold the foot pedal down all the way. Ain't it fun to tear stuff apart, looks good.
The Cub Cade Drive System Oil is a Hydrolic - Transmission oil so I was actually now leaning towards running HyTran through it versus Rotella. |
All fixed and put back together, no leaks and mows flawlessly.
Thanks for the help and input guys. |
